My name is Bake. You can call me Bake. This is the first time I've posted on Overclock, read lots of your threads but I need some help now. I have an Amd Athlon 64bit 3200+ ridding on a Gigabyte K8Triton Nforce 4 Sli Ready. I put Thermal Paste on it two times and I'm still getting 70 degrees Celsius constant. I was curious if anybody had any ideas on how to fix this or If it might be a faulty sensor. If you think its a faulty sensor anybody know where I can get a cheap one to verify this claim???
Any comments or help would be appreciated.
Bake
Edit: Yes I cleaned the paste off properly after the first time with Rubbing Alcohol and Q-Tips.
Bake
