Looking to make FireFox faster for you? Check this little setup out's it's made a noticable difference in page load times for me.
Requirements:
1. You have FireFox (duh)
2. You have broadband
Here's how to do it:
1.Type "about:config" into the address bar and hit enter. Scroll down and look for the following entries:
network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
Set "browser.turbo.enabled" - to "true"
Set "network.dns.disableIPv6 - to "true"
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives.
If you're using a broadband connection you'll load pages MUCH faster now!
If you've found this helpful, toss me a rep
Requirements:
