1 - 13 of 13 Posts
Originally Posted by RubberDucky
So far im at 3.3 going for 3.4 my psu btw is a http://www.newegg.com/Product/Produc...82E16817148008
i bet u can hit 3.7-3.9 stable when your done,maybe more...im at 3.7 w/ cheap value pc3200 @1:1, and im stable as a rock...
I sayd check for stablitly at 3.4, but i bet your temps will be perfect with the XP-90 and AS5.....get that puppy to 3.6 and run Prime 95 for 12-25 hours to make sure for stability
good luck
sweet, sounds like a plan... good luck w/ prime
are you at stock voltage?
no im at 1.42 from 1.38 stock... but cpuz reads as 1.34...lol dunno why, its at 1.42 in bios...
ya u have a xp-90 i have stock cooling in a tiny case... thats the only thing holding me back right now is my temps... im at about 56-58 load,42 idle
PS: check above post to see cpuz...
Wow Rubberducky you can rpolly push it to 4.0 if your REALLY lucky, and with great temps.....but ill say you get to 3.8 perfectly
1 - 13 of 13 Posts
