I'm having some difficulty here. I recently purchased a 32'' Emerson HDTV and decided to use it as a monitor with my PC via HDMI. It's been working great except for with 1 game that's been causing me a mountain of trouble.
I've been trying to troubleshoot this and as far as I can tell... Basically, the issue is that the game, unlike pretty much every other program in existance, uses the max available resolution according to my monitor's EDID instead of my current one. This monitor I'm using can only display at 1360x768 otherwise everything looks blurry. The problem is that the monitor's ''Max'' resolution, according to my PC is 1920x1080 so this game just defaults to that resolution every time it runs.
I asked around on the forum for the game itself and the only method that seems to be available to fix this issue is to edit or override the EDID. I tried following a guide and downloaded "Extron EDID Manager" and "Entech Monitor Asset Manager" but these programs are so unintuitive that I'm having trouble making heads or tails of them. This isn't exactly my area of expertise in the first place.
But anyways, according to my resolution settings, my monitor can support...
1920x1080
1776x1000
1680x1050
1600x900
1440x900
1400x1050
1366x768
1360x1024
1360x768
1280x1024
1280x960
1280x800
1280x768
1280x720
1152x648
1024x768
800x600
But none of these resolutions can display properly on my TV except 1360x768. So I need a way to disable atleast every resolution above that. Or a way to override this game's ability to change my resolution.
I'm currently running, Windows 7 64-bit. I have a Radeon HD 5750.
Can anyone help?
1920x1080
1776x1000
1680x1050
1600x900
1440x900
1400x1050
1366x768
1360x1024
1360x768
1280x1024
1280x960
1280x800
1280x768
1280x720
1152x648
1024x768
800x600
Can anyone help?
