hello.
im building a new computer next month, and i will primarilly use it for gaming.
i have a budget of £300 (about 492 us dollars) and no higher.i know it isnt allot but its all i have
i have decided on the case (cm690) and the gpu(xfx 4850xxx,) but i need to decide more on the cpu and motherboard. ive chosen the e5300 as the cpu but if there is a better one at the same price or cheaper let me know. ive decided to use the silver power SP-SS500 as the psu because it is fairly cheap and ive heard its high quality
now,
i could buy the gigabyte ga-p31-es3g which is £44 and with the budget i have takes it up to £299.
or is it worth it me cutting back on the power supply ive chosen (a silver power 500w) to get a ASUS P5Q SE which is about £20 more but from what i understand overclocks better. but will the worse power supply effect it
what do you think is the best for me out of the two, and are there any good parts in my price range that are better than my currently chosen ones.
thanks, alltoasters.
now,
