Looks okay--hard to know without knowing what waterblock that really is under that plate...
Originally Posted by Zyther how do i get ambient temp, that the temp in my case? cuase in asus pc probe it says my motherbaord temp is 47c at load |
Originally Posted by Zyther I have a P4 550 socket 775 3.4ghz it gets pritty hot where i live, and my idle temp is 50c and load is 71c, this is with arctic silver 5 and a thermal take blue orb 2. i want to get this water cooling kit, anyone know if its good? what temps would i get from it? kit: http://www.xspc.biz/kits.php reveiws: http://www.modthebox.com/review435_1.shtml http://www.overclockers.com/articles1282/ http://www.moddin.net/review.asp?ReviewID=195 |
Originally Posted by Zyther my room temp is 30c because its summer here, and i put a thermoniter and ran a tortue test and the thermoniter is saying the temp in my case is 43c, i have 1 12cm fan at the frount for intake, 9c at the side for intake, and a 12cm fan on the back for intake, 8cm one on my psu for intake and 8cm one on the psu for outtake. |
Originally Posted by DrDeville Hmmm... that sounds a bit unbalanced to me--much more intake than exhaust. If so, you're trying to blow up your case like a balloon, and not moving much air. ![]() ![]() You might try switching one or more fans to exhaust, and see what happens--I suggest the rear. HTH, and stay cool. ![]() |
Originally Posted by Zyther opps heres the correct thing, psu with 2 8cm exhaust 1 12cm exhaust at the back 9cm intake at side 12cm intake at forunt |
