1 - 5 of 5 Posts
There is a setting on the Asus P5B Deluxe Bios in the jumperfree settings called pci express frequency does this overclock the pcie16x slot and how do the numbers work they start at 90. is 90 lower or higher than the default setting has anyone else played around with these and can it improve graphic performance? is there a multiplier and if so what is it.
100 is stock, sometimes people bump it up a little bit.
Reactions: Madmaximus
100mhz is good for the video card you have if you were running Quad SLi i could say that overclocking will help some
Discussion Starter #5
Thank you guys for being so helpful
1 - 5 of 5 Posts
