1 - 3 of 3 Posts
The Q-Fan function does not appear to work on my board. The BT fan speed stays at Max. with all settings. Also, SpeedFan does not even show the fans if you try to configure 'speed".
I think you have to enable that throug the BIOS. If AISuite can't that is.<br><br>
Also, I used to use that but it didn't worked that good in my P5WD2-Premium, so I ended up disabling the Q-Fan.
I remember when......
Haven't tried the Q-fan on my P5B Deluxe yet (trying to get the Wi-Fi and display hammered out first LOL)....but it never really worked on my P5WD2-Premium either........course, my systems run 100% 24/7 anyway, so it never bothered me......
1 - 3 of 3 Posts
