1 - 9 of 9 Posts
<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><a href="http://support.asus.com/download/download.aspx?SLanguage=en-us" target="_blank">http://support.asus.com/download/dow...Language=en-us</a><br><br>
P5B Deluxe Release BIOS version 0711<br>
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode<br>
2. Add check ATI CrossFire VGA card routine<br>
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature<br>
4. Reduce system full reset of times<br>
5. Patch some VGA card can''t found when NB Vcore value has been set too high<br>
6. Fix DDR frequency 889 unstable by SPD<br>
7. Enable support for NVIDIA 7950GX2 cards under recovery mode<br>
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable<br>
9. Fix memory display message not correct under multi-language<br>
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU<br>
11. Fix chassis fan 2 speed not correct when fan speed too low<br>
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU<br>
13. Enhance Chassis Q-Fan sensitivity<br>
14. Improve memory compatibility
The Asus P5B also have a update for it bios too, 0701. <a href="http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B" target="_blank">http://support.asus.com/download/dow...n-us&model=P5B</a><br>
Yay, this update fixed Chassis2 problem ^)^
I updated my bios and YAY!!No more stupid shutdown everytime BIOS is saved, no more stupid shutdowns on restarting, no more HDD power-downs and that scary clicking! Thanks ASUS and crossfire support
Discussion Starter #4
Anyone who has P5B deluxe, This bios is very well recomended. I got a better OC result on this bios too<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>sladesurfer</strong>
</div>
<div style="font-style:italic">I updated my bios and YAY!!No more stupid shutdown everytime BIOS is saved, no more stupid shutdowns on restarting, no more HDD power-downs and that scary clicking! Thanks ASUS and crossfire support</div>
</td>
</tr>
</table>
</div>Do you mean that this BIOS corrects that annoying "power-on, power-off, then full power-on" issue?<br />
<br />
Please say it's so...
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>Syrillian</strong>
</div>
<div style="font-style:italic">Do you mean that this BIOS corrects that annoying "power-on, power-off, then full power-on" issue?<br />
<br />
Please say it's so...</div>
</td>
</tr>
</table>
</div>YESS!!!!<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Correct .. have been using this for the past day and it stops most of the restarts so will help save your HW, Pumps, compressors .... it will still do some restarts when timings are changed such as from 1:1 to 2:3 ... but otherwise a much better BIOS.. Plus it opens up the Cross-Fire option for those who have those GPUs
<tr>
<div>
</div>
<div style="font-style:italic">YESS!!!!<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>Oh, thank Buddha! I know what I'm doing tomorrow! <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
Okay, I re-flashed the BIOS and guess what.... No Pause!!! Thankyouthankyouthankyou for the "heads-up"
I remember when......
Downloaded it now onto my work laptop just in case they decide to remove it form the site like they do sometimes LOL<br />
<br />
<br />
Sounds great....sadly, thanks to some very annoying Windows bugs, some unique problems using my 42" HDTV for my monitor, and the lack of any instructions regarding installing the Wi-fi on my board......I haven't even been able to play with my system much....although I did manage to break in the CPU. Hopefully I can get it set up for good tomorrow and play with this BIOS.....
1 - 9 of 9 Posts
