1 - 5 of 5 Posts
P5B Deluxe here with XP Pro sp2. After installing drivers for everything there are a couple of weird things happening..<br />
<br />
-I still have an "unknown PCI device" in the device manager<br />
<br />
<br />
-When I plug in a firewire external drive, the "Found New Hardware" Wizard pops up, and the Dev Mang shows an unknown dev entry for "DMI HID". The drive works fine though.<br />
<br />
Maybe these two things are related somehow. I have the onboard audio disabled in the bios, btw (running an Audigy2 card).
Discussion Starter #2
Ok, just found out the "DMI HID" thing is related to my external drive needing the backup push-button software installed. <br />
<br />
Unknown device still unsolved.
right click and reinstall drivers, I did have that once happened to mine but it was solved that way. <br />
<br />
Also install the AISuite, that could also be it.
In the Bios Disable HD Audio Controller <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
He did-> check tha 1st post. Reload your drivers as Nas said, you might even try loading the performance defaults in BIOS. For some reason, asus has funny issues in their BIOS settings, IE things reset or dont work right until you reset the board.
1 - 5 of 5 Posts
