P5N32-SLI Plus with ATI HD 4870 X2
447 Views 6 Replies 3 Participants Last post by  ACHILEE5
Hi,
Well i was going to go for a GTX285ssc but i don't want to wait for them to be back in stock!
So now i'm looking at the ATI Radeon HD 4870 X2 2048MB
But will it work with my NVIDIA Chipset Board
Thanks
Gary
1 - 7 of 7 Posts
Originally Posted by zero0zero0
It'll work, just you can't Crossfire.
Does that mean, i wont be able to use both cores on the card
Or, i just wont be able to add a second card
It just means you won't be able to use a second card. You will be able to use both cores on the 4870x2
Since the two GPUs are on the same PCB, it's a 'virtual' crossfire, with the crossfire control core being inside of the PCB itself, instead of on the motherboard as you would have with a dual card configuration.
Now, I'm not sure why you'd want a second 4870x2...
So, i wouldn't change any thing in the Bios
But i would have Crossfire controls in control panel!
And i would only get full force out of the card, if the game supported Crossfire
Exactly.
There's a tool out now that forces crossfire compatibility with all games, you might try looking into that if you're concerned about low performance.
1 - 7 of 7 Posts
