1 - 9 of 9 Posts
Maybe a stupid question, but can a motherboard limit your overclock??? I'm stuck at 420 FSB and don't know how to get past it. I suspect it's my mobo, my ram, or my BIOS settings... not sure. See my sig rig for system details. Here are my BIOS settings:
Ai Overclock Tuner......................[Manual]
CPU Ratio Setting.......................[8.5]
FSB Frequency...........................[420]
PCIE Frequency..........................[103]
FSB Strap to North Bridge...............[Auto]
DRAM Frequency..........................[Auto]
DRAM Timing Control.....................[Auto]
  1st Information: 5-5-5-18-3-52-6-3
  2nd Information: 8-3-5-4-6-4-7
  3rd Information: 14-5-1-6-6
DRAM Static Read Control................[Auto]
DRAM Read Training......................[Auto]
MEM. OC Charger.........................[Auto]
Ai Clock Twister........................[Auto]
Ai Transaction Booster..................[Auto]
  C/P: A1 A2 A3 A4 I B1 B2 B3 B4
  LVL: 13 13 13 13 I 13 13 13 13
CPU Voltage.............................[1.2625]
CPU PLL Voltage.........................[Auto]
FSB Termination Voltage.................[Auto]
DRAM Voltage............................[Auto]
NB Voltage..............................[Auto]
PCIE SATA Voltage.......................[Auto]
Load-Line Calibration...................[Auto]
CPU GTL Reference.......................[Auto]
CPU Spread Spectrum.....................[Auto]
PCIE Spread Spectrum....................[Auto]
CPU Clock Skew..........................[Auto]
NB Clock Skew...........................[Auto]
CPU Margin Enhancement..................[Optimized]
C1E Support.............................[Disabled]
Intel Virtualization Tech...............[Disabled]
CPU TM Function.........................[Enabled]
Execute Disable Bit.....................[Enabled]
Here are some options to change:
PCIE Frequency..........................[100]
FSB Strap to North Bridge...............[333]
DRAM Frequency..........................[667] <-- Set to 667
DRAM Static Read Control................[Disabled]
DRAM Read Training......................[Disabled]
MEM. OC Charger.........................[Disabled]
CPU Voltage.............................[1.2625] (1.35-1.45)
CPU PLL Voltage.........................[1.5]
FSB Termination Voltage.................[1.2]
DRAM Voltage............................[Auto] (Varies on what your RAM is)
NB Voltage..............................[1.3]
Load-Line Calibration...................[Disabled]
CPU GTL Reference.......................[Disabled]
CPU Spread Spectrum.....................[Disabled]
PCIE Spread Spectrum....................[Disabled]
CPU Margin Enhancement..................[Compatible]
Execute Disable Bit.....................[Disabled]
[/QUOTE]
Tried the above settings and got BSOD during Intel burn test. Googled my problem and it seems as if my mobo is limited to about 420 to 430 FSB - so I think I'm stuck where I'm at.
One remaining problem - I went back to my old bios settings and during Intel burn test I see my multiplier drops from 8.5 to 6 in CPU-Z. I've noticed this happening before when I'm about 20 minutes into prime95. Why is this?
1 - 9 of 9 Posts
