Any HDD one will work, thats what I did for mine. Just make sure your not replacing a HDD, or else your bios might freak *mine did*
Edit: But it works fine now of course.
ICH10R Serial ATA connectors (7-pin SATA 1-6 [red]) These connectors are for the Serial ATA signal cables for Serial ATA hard disk drives. [...] These connectors are set to Standard IDE mode by default. In Standard IDE mode, you can connect Serial ATA boot/data hard disk drives to these connectors, set the Configure SATA as item in the BIOS to [RAID]...... |
