1 - 5 of 5 Posts
parts:
ASUS P5QC LGA 775 Intel P45 ATX Intel Motherboard - Retail, EVGA 512-P3-N861-TR GeForce 9600 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail,OCZ SLI-Ready Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model OCZ2N1000SR4GK - Retail, COOLER MASTER eXtreme Power RP-550-PCAR 550W ATX from factor 12V V2.01 Power Supply - Retail , ZEROtherm Nirvana NV120 120mm 2-ball UFO Bearing / Transparent CPU Cooler - Retail, Intel Core 2 Extreme QX6850 Kentsfield 3.0GHz 2 x 4MB L2 Cache LGA 775 130W Quad-Core Processor\\
Goal:
3.5ish stable!! help or suggestions is greatly appreciated!!
Welcome to OCN!
First, fill in your system specs.
Second, I suggest you send the QX6850 back for a refund, buy a Q9550 and keep the leftover few hundred bucks. The reason is that 3.5 is hardly an effort justifying the extreme expense of a QX6850, especially when many Q6600s and virtually every Q9550 will go that far, or farther.
For instance, I run my Q6600 at 3.6GHz under 24x7 load.
posting an update... i got it up to 3.8 stable and goal just moved up to 4.0 flat... ONE PROBLEM still though... mem hangs or dumps when i go past 3.8 even by .01 . the settings are NOT helping of 5-5-5-15 stock and mine are at 8-8-8-24 at 3.8 CPU speed. if anyone can help please let me know in any suggestions.
k can't NOT get the processor to pass the POST test. atm it is 400fsb and multi of 9 at 3.6 VERY stable but i am curious to see if it can be done to reach 4.0 flat. i think the mem timings are not what is helping me. please help if you can!!
Looks like you decided to keep the chip instead of getting something better.
I'd suggest you go with 400x10. I don't know how well your RAM will OC, if at all.
1 - 5 of 5 Posts
