I have 3x2g sticks installed but bios only recognizes 4gig total and so does windows 7. However cpuz is reading all 6 gigs. Im not sure if the computer is really using 6 or 4... If anyone has some insight please let me know.
BTW I did check each stick individually and they all work when installed alone. And they are all in the slots recomended by the motherboard manual.
Right click my computer and click properties. That will tell you the amount of ram available for use by windows. Make sure its 64 bit and some motherboards have a setting to enable above 4GB I think.
I think there may be a setting that limits the ram able to be used up in windows for compatibility purposes. Dig through the BIOS to see if there is anything relating to RAM.
Try clearing the bios. If that doesnt work, try testing the modules and see if any are bad. Not you can not run a single stick of memory in the first dimm (closest to the CPU).
Isn't there an issue with the V2's and more than 4 gigs of ram? I honestly can remember seeing at least 3 threads JUST like this over the past 6-9 months. Maybe try searching for an old thread to see what the other V2 users have done.
This P6T board has a problem of not detecting all 6GB of ram sometimes, even in the BIOS. My bro has the P6T vanilla and it happens mostly at cold boot. It can be caused by too much tension in the heatsink, which may misalign some pins from proper contact with the contact pad on the CPU. It could be insufficient QPI or DRAM voltage (stay at 1.65v and below for DRAM voltage).
Overclock.net
