1 - 4 of 4 Posts
Hi to all!
Help me please
I have this Mboard
http://www.asus.com/Motherboards/Intel_Socket_1366/P6X58DE/
and I have installed 3x2gb memory G-skill ripjaws PC3 16000/2000 runing in X.M.P. mode at 2000 and 2100 , with no problem and I have cooler on them
So if I will buy cheap memory not triple chanel
http://www.newegg.com/Product/Product.aspx?Item=N82E16820103010
3x4gb ddr3 1333 will my mboard be able to run g-skill into X.M.P. and cheap memory without X.M.P , or I must to run all with default mode.
or how will be it compatible?
Thanks.
If your asking about using 2 different types of DDR in your system at the same time id probably give it a miss as you will likely run into problems regarding timings and experience instability.
Its worth a try if you allready have the ram with you but im sure it will cause instabillity.
Originally Posted by Viktorik View Post
Hi to all!
Help me please
I have this Mboard
Thanks.
It will run at the slowest default mode and you can mix them.
For more details; Desktop Boards - Single, dual, triple, and flex memory modes - Intel
1 - 4 of 4 Posts
