1 - 4 of 4 Posts
right now i have it running at vccsa 1.0
and vccio at 1.15 is that fine or too much for the i7 2600k
Thanks!
anyone has bois setups for over 4.5... if I try 4.8 with offset the voltages go well over 1.48V and my cpu tops 90+C so I throttled back to 4.5 @ 1.4V and it primes at +-60C any suggestions on my setup?
Thanks for the help!!
Washed Up Old Gamer
search out the sandy stable club in that google box top right corner. you'll be glad you did.
Reactions: Night197
Read this thread. He didn't know much at all on overclocking SB. I walked him through finding what his chip needed and got him up to 4.8ghz using offset running prime blend on air with load temps at 72c. He need to do more stressing.
You can use this as a quick quide for what your asking for.
http://www.overclock.net/intel-cpus/...ted-ocing.html
1 - 4 of 4 Posts
