1 - 5 of 5 Posts
Ok so im curious. Of the three programs which can consistently crash your computer the quickest?
I primarily use IBT (Intel burn test) mostly because it has a freeze test and i feel it crashes me alittle quicker
I've been stable through 20 passes of LinX with 20000 problem size, but BSOD within minutes of P95. I can also get away with 5 passes of IBT but still be P95 unstable. So recently, I've been using P95.
Bowser Has Ryzen!!
For temps I will def say LinX or ITB. P95 cant raise your temps as high, but for longterm stability use P95. Most I believe do passes of IBT or LinX to test for some stability and then do the 8-12 hrs of Prime to test for real.
^ This. IBT and LinX are good for finding max temps, but for long-term stability, definitely P95.
EDIT: I use blend for P95.
1 - 5 of 5 Posts
