What do you guys think of painting a pc case in chrome/nickel colour? I am refering only to external painting-->front panel, top panel, side panels which are made of plastic and steel. How will the chrome look on those? Will this colour look different in those 2 types of material?(had this problem with another type of gloosy paint..) Do i need to do any special preperation of steps before that, other than sand,prime,paint,clear-coat? I also heard that if you clear-coat the chrome it becomes like silver, which i dont want. I want that mirror look on my case. Is it worth it? What do you think?
