I know there are a lot of you out there with great painting skills that might be able to help me out here. I have applied all of my color coats and have achieved the right look that I am going for. I am using Dupli-Color Chrome rattle-can paint. After about 3 applications and letting it sit for about a week - the color looked perfect. Almost as if I had chrome dipped the pieces. The problem that I have is that I just did my first piece with the clear coat to protect the paint...and now it looks horrible. It lost all of it's "chrome."
What was a shiny chrome look - has now turned into a grey. It still appears shiny from the clear coat, but it does not look like the "chrome" anymore. It's been about 3 hours since I put the first clear coat on and it still looks grey.
What the heck happened? Any ideas here?
