Painting Antec 900 Interior
726 Views 8 Replies 7 Participants Last post by  cs_maan
What kind of paint for painting the inside of a case? I just want it to look similar to the outside so I'm assuming a flat black would be fine. Any special kind of paint I would have to use?
1 - 9 of 9 Posts
there's a few guides on ocn, just look it up on google, i'm to lazy to search
I would use Satin, not flat. Satin isn't real shinny like Glossy but it isn't as dull as flat. Satin will most likely match the outside of your case the best. No special paint is needed, regular spray paint will due. You will need to get some primer and sandpaper also.
ty much! thats what I wanted to know
satin is the way to go. just remember to take ur time. an abrasive primer, then a normal primer, then the satin, and finally a clear. sanding after every step except abrasive primer and moving to a higher grit sand paper every time. it will look awesome guaranteed if you do it slow.
Thats the way I do it as well. You will feel like a pro after the job... But dont take short cut and take your time between spraying . Make sure you do a LIGHT coat every step so you dont get drips.
I use the Automotive paint at Advance Auto parts and if you get the dark bumper coat, that stuff goes on so easy that anyone will look like a pro. If you want to get crazy. Get the bright red Brake Caliper paint. That would light up the inside of that antec case big time.
do I have to sand it down completely first? or would it be okay if I just rough it up a little with sandpaper?
You dont have to sand it down completely, just rough it up real good to with 220 grit sand paper make sure you hit the entire panel with the sandpaper by scuffing it. Use satin black like the other members mentioned. It is single stage paint most times you will use. Which should not be clear coated. Check out my project below, and the quick guide for interior tips. I put pictures here to show what my project looked like if you did the satin black. Hope this gives you a idea. Any further inquires just give a shout.
Wow that looks WAYYY better than my A900 paint job that I completely butchered by rushing
DON'T rush! That is the single most important thing to remember
. Or your case will end up looking like you dipped it in tar....which is what mine looks like
1 - 9 of 9 Posts
