I know some brands also sell front panels in differnet colors, not sure if it exsits for that one though.
If not, spraying it with a silver colored paint could be nice if you do it properly. But it's easy to mess it up.
Also, Lian Li sells front panels for their cases, but don't knwo if they'll fit yours though. Depends on whether or not your able to fasten it in front of the drive on the case, but doesn't seem like it's that easy taking the side panels of that case since it seems to be in one piece?
If not, modding the drive somewhat to fit back the front panels there could also work.
