1 - 7 of 7 Posts
I got bored at work so I broke down my work PC and set it up on some anti-static foam sitting on my desk. Then I proceeded to break down the case.
I have already done a little bit of painting to the mesh (painted it red) but I wanna take this a little further. I broke the entire case down to the most simple parts I could (without removing the rivets, that's coming). I am planning out a white/black exterior, black interior, keeping the mesh red but I am gonna sand blast it and repaint it (hopefully a better paint job than before) with two white racing stripes down the middle. I am not going to make a log because this is going to be a very short simple mod without a lot of update posts.
Only thing stopping me from painting mine now, is procrastination.
Without my case, I can't play my games
Although thanks to my mod, I won't have nearly as much to paint as you guys
*cough*
still trying to decide on a color scheme for it though... that is a tough one =|
Good luck with the paint! subbed
Edit: Is that chrome trim a PITA to take out or what? sheeesh
Discussion Starter · #6 ·
*cough*
Tell me about it. I think I spent just as much time getting the trim out as I did with getting everything else taken apart. A small flathead and some patience will help though. I ended up getting frustrated and I broke one of the tabs but no big, it won't affect anything.
You should do like I did and just set up your rig on a piece of foam or something. I can still use the PC b/c I set it up kinda like a test bench on my desk.
Glad to see I'm not the only one who broke off a tab
The problem with setting it up for me, is that I lack desk space, lol.
I should be getting my tub of Bondo tomorow, so I'll finally be starting the paint sometime next week. By then I hope to have found a way to keep my computer running without the sexy case, for a little while, anyways.. =[
1 - 7 of 7 Posts
