1 - 4 of 4 Posts
Hi
Recently my friend just bought this gpu for his rig
The problem is this card make a very loud noise like a vacuum cleaner even tough not plying any games, even 10 - 20 sec after startup.
but not continuously, maybe at 10-15 minutes interval
is it normal for this card? thats why it named "jetstream"?
Jetstream, that's not ironic given issue. Have you tried forcing a custom fan profile using MSI Afterburner? That may prevent the card from unnecessarily spinning up the fans.
Now, if the fans crank up because the temps are spiking, then you would need to look into that issue.
He used MSI afterburner to set the fan curve but its still the same, eventho the temperature is at 30 the fan speed is at maximum.
I've no experience with Palit cards. But in all the cards I've had, I've never had a card ignore the fan profile I've set in MSI afterburner. If he set the fan profile low and the fans still crank up periodically, ignoring the fan profile he set, then I am stumped.
Sorry I couldn't help more.
1 - 4 of 4 Posts
