1 - 11 of 11 Posts
I will be getting either one of them today but i'm not sure which is better. Does anyone have any problems with either of them? In Singapore, PoV is selling for $225SGD and $239 for the Palit one. These 2 are the cheapest 460 i could find and was hoping to get some opinions of them. Thanks in advance.
Point Of View is a good brand. So no worries there. So is Palit.
I have no experience with Leadtek whatsoever.
Discussion Starter · #6 ·
Thanks guys. Got the Palit one. I tried running in MSI Kombuster for benchmarking but i'm seeing like lines moving from left to right near the end of the test where the FPS is around 20~30. Is that wad's called artifact? Using the card as it is without any OC(Palit GTX 460 Sonic 1GB).
Uploaded the SS. The FPS suddenly dropped to 19 when it reaches this part. I'm not sure if this is the problem with the card or the program. My friend using the 768mb version is also having the same problem.
1 more question. What do you guys usually do when you get a new card to make sure it's running well?
Discussion Starter · #11 ·
The Palit one was more exp than the PoV. But it was out of stock when i got there so i went for Palit instead.
Originally Posted by fsf
I have that problem too.. those lines, it happens exactly the same as you do.. I'm thinking the problem is not the card itself.. I actually thought it was part of the program oO
I see. Thanks for that valuable info. I'm thinking the same way too.
1 - 11 of 11 Posts
