Part 1-Temp's With and With-Out Shrouds
21297 Views 64 Replies 18 Participants Last post by  ira-k
Temp's With and Without Shrouds
Part One With Shrouds
This is part one of a 4 part test.
1-Testing with shrouds.
2-Testing with-out shrouds.
3-Testing with low cfm 120x25mm fans.
4- Testing the optimum placement of fans on a GTX rad.Flow in the GTX runs from front to back.
This test is being done at CrazyJoe's request.
Testing was done on a loop comprised of the following.Stinger V-8 DO 320W Pelt Block,2x18W
DDC with Petra's Top, 480 GTX Rad with 4-108cfm Sunon and 4-115cfm Panaflo in matched pairs from front to back and about 6 feet of tubing I also had a double in res for the DO Stinger.Loop pressure was 9psi for all the tests.
I have a 3/4" shroud on the pull side of my rad and 1/2" shrouds on the push side of my rad. Fans and shrouds have clear silicone sealing the edges for a fairly air tight seal.
Heat load; 150 Opty stock 85.5W. 15V 320W Pelt run at 12V 235W. Total Wattage 320W.
I ran one hour of Prime 95 large FFT's, Measurements were taken in 10 minute intervals.Idle
temp's were taken after 15 minutes at idle.
These tests were run with uncalibrated equipment and are meant only as a very simple test.The inline temp probes are the Alphacool brand inserted in a plastic T the tips are right in the flow.One before the rad and one after I have them attached to Compu-Nurse readouts.The air in and air out temp's are from flat tape thermisters attached to a CM Areogate read-out. Room ambients are taken with a flat thermister attached to a Compu-Nurse read-out.The hardest part was keeping the room ambients the same. I finally gave up and just averaged out room ambients which will skew results some itself.
For all of the temp's I threw away the highest and the lowest full load readings and averaged out the other 4.I used the core-temp from Speed Fan 4.32 and Core Temp 0.95 which ever one was highest.
**This testing is done on a fairly thick rad with a high FPI count,2.13" thick with 20 fins per inch,results with thinner rads and lower FPI count will be different I would think in the push results mostly.
I will wait for all testing to be completed before I try to draw any type of conclusions from my
readings.But as you can see water temp dropped across the rad becomes less with less air
flow and the air temp's across the rad become more with less air-flow.
Please see following pic's for screen shots.They were taken in the final minute of each test.
Push-Pull With Shrouds
------------Idle-----Minutes--10----------20---------30----------40----------50--------60----------Average
Ambient---29C---------------29.5-------29.5-------29.5---------29---------29.5------29-----------29.375C
CPU-------- -4C-----------------6-----------6------------7------------6----------6----------5-------------6C
Water In---32.5C------------33.1-------33.2--------32.9-------32.8--------32.7-----32.5--------32.725C
Water Out-31.2C-------------32.1-------32.4--------31.7-------31.2-------31.8-----31.1--------31.7C
Air In--------27.5C------------28----------27.5--------27.5-------27.5-------27-------27-----------27.375C
Air Out-----31.5C------------32.5--------32-----------32---------32----------31.5----31.5--------31.875C
CPU temp is 23.375C below room ambient. Ambient 29.375C
Water temp dropped across rad 1.025C
Air temp dropped across rad 4.5C
Pull Only With Shroud
------------------Idle---Minutes--10---------20----------30--------40---------50---------60----------Average
Ambient------28C-----------------28---------27.5-------28-------28.5-------29.5-------29----------28.375C
CPU---------- -3C-------------------6----------6------------7---------8------------8-----------8------------7.25C
Water In----32.1C----------------32.8------32.5--------32.7----32.9--------33.5--------33.8--------32.75C
Water Out---31.6C----------------31.3------31.5--------31.5----31.3------32.5----------32.7--------31.7C
Air In----------26.5------------------26.5------26.5--------26.5-----27--------27-----------27.5--------26.75C
Air Out-------31.5-------------------32---------32----------32--------32--------33-----------33.5--------32.25C
CPU temp is 21.125 below room ambient. 2.25C hotter then Push-Pull. Ambient 28.375
Water temp dropped across rad 1.275C
Air temp dropped across rad 5.5C.
Push Only With Shroud
-------------------Idle---Minutes--10----------20---------30--------40----------50----------60-------Average
Ambient------28.5C--------------29.5--------29.5-------29.5-----29.5-------29.5-------29.5-------29.5C
CPU------------ -4C------------------8------------9------------9---------9-----------10----------10-------9.25C
Water In------31.9C--------------34.1--------34.2-------34.2-----34.3--------34.2-------34.2-------34.2C
Water Out---30.2C---------------32.4--------33.2------33.1------33.6--------33.1-------33.5------33.35C
Air In----------26.5C---------------27.5--------27.5-------27.5------27.5-------28----------27.5--------27.5C
Air Out-------31C-----------------33.5---------33.5-------33.5------33.5-------33.5-------33.5--------33.5C
CPU Temp is 20.25 below room ambient. 3.125C hotter then Push-Pull
Water temp dropped across rad 0.975C . Ambient 29.5C.
Air temp dropped across rad 6C.
Passive With Shroud and Fans Still Attached
I only ran this test for 40 minutes.I just don't like my loop running that hot. I know it wasn't really that hot but I'm just weird about my temp's.I am also going to run it passive when I take off the shrouds in the second part of this test.I would think with the shrouds and fans not holding the heat in that it will cool a little better.
I added a probe to the top upper side of my rad in this test I was about 5 minutes into it before i thought of adding one.It is the hottest part of the rad.I wish I had thought to of placed one on the middle and bottom part also for all of this testing.The middle seems fairly cool and the bottom warm but not as much as the top.My rad is inverted so my
barbs are at the bottom.
I averaged all 4 temp's on this test.
------------------Idle-----Minutes--------10-----------20----------30---------40-------------------Average
Ambient------24C------------------------26-----------27.8--------29.5-------29.5-----------------28.2C
CPU------------ -1C-----------------------17------------20----------22----------24-----------------20.75C
Water In-------39C-----------------------48.6--------51.5--------53.5------54.4------------------52C
Water Out-----38.4-----------------------48----------51.1---------53.2------54.3------------------51.65C
Side of Rad------?-------------------------39.8-------41.4---------43.5-------44--------------------42.175C
CPU temp is 7.45C below room ambient. 16.3C hotter then Push-Pull
Water temp dropped across rad is 0.35C
Testing with-out shrouds to follow. If you see any mistakes let me know and I will correct
them while I still have my written notes. If you would like me to add anything let me know
and I will if I can.
Reactions: 5
1 - 20 of 65 Posts
Rad Shroud Testing
Part 2 - With-Out Shrouds
This is part 2 of my rad testing with and with-out shrouds. All loop components remain the same. Stinger V-8 320W Pelt block,2x18W DDC's with Petra tops, 480 GTX Rad and about 6' feet of tubing. Psi was 9psi for this test as well as the previous test.
I ran 60 minutes of prime 95 with large FFT's recorded at 10 minute intervals for 60 minutes. Then I threw away the highest and lowest full load temp's and averaged them out. Idle temp's were recorded after sitting idle for 15 minutes.
I taped around the fan to rad junction with masking tape for a fairly air tight seal.
Push-Pull With-Out Shrouds
------------------Idle------Minutes-10--------20----------30--------40---------50---------60--------Average
Ambient----25C--------------------25.5-----25.5--------25.5------26---------26-----------26---------25.75C
CPU-------- -5C----------------------5----------5------------6--------6------------6------------6-----------5.75C
Water In---28.7C-----------------29.1------29.2-------29.4------29.5--------29.6--------29.6------29.425C
Water Out -27.3C----------------27.7------28.7--------28.7-----28.5--------28.7---------28.2------28.525C
Air In----------24C-----------------24.5-------25----------25-------25-----------25.5--------25.5------25.125C
Air Out-------27C------------------27.5------28-----------28--------28----------28-----------28--------28C
Average temp is 19.75C below ambient which is 3.25C hotter then push-pull with shroud.
Average water temp across rad is 0.9C.
Average air temp drop across rad is 2.875C.
------------------Idle----Minutes--10---------20----------30---------40---------50---------60---------------Average
Ambient------28C-----------------27.5-------27.5-------27--------28.5---------27.5-------28---------------27.625C
CPU----------- -4--------------------9------------9-----------9---------11----------10---------10-----------------9.5C
Water In------32.5C--------------32.7--------32.5-------32.2-----31.1--------32.7------32.6-------------32.5C
Water Out---31.2C--------------31.6---------31.8-------31.4-----31.8--------31.5------31.8-------------31.675C
Air In----------26.5C--------------26.5----------26.5-------26--------27.5--------26.5------27---------------26.75C
Air Out--------31C-----------------32------------31.5-------31.5------32.5--------32---------32--------------32C
Average temp 18.125 below ambient which is 2.875C hotter then pull with shroud.
Average water temp drop across the rad 0.95C.
Average air temp drop across rad 5.25C.
Push Only With-Out Shroud
----------------Idle-------Minutes--10---------20---------30----------40---------50------------60-----------Ambient
Ambient-----27.5C------------------27.5------27.5-------27.5-------27.5-------27-----------27-----------27.375C
CPU---------- -1C----------------------9-----------9-----------8----------10--------10-----------10------------9.5C
Water In-----32C--------------------33.1--------32.4-------32.4-------33.2------32.1-------32.5--------32.8C
Water Out--31.7C--------------------31.9-------31.5-------31.4-------32.1-------31.7------31.6--------31.625C
Air In----------24C---------------------24---------23.5-------23.5-------24---------23.5-------23.5-------23.625C
Air Out-------31C----------------------32---------31----------31----------32---------30.5-------30.5-------31.125C
Average temp is 17.875C below ambient which is 2.375C hotter then push with shroud.
Water temp drop across rad 0.875C.
Air temp drop across rad 7.5C.
Passive With-Out Shroud
Coming Soon...
Comparisons......
Push-Pull with shroud average below ambient.....23.375C...3.625C cooler
Push-Pull with-out shroud average below ambient........19.75C
Pull only with shroud average below ambient.........21.125C......3C cooler
Pull only with-out shroud average below ambient..........18.125C
Push only with shroud average below ambient......20.25C.....2.375C cooler
Push only with-out shroud average below ambient..........17.875C
Water temp drop across rad with push-pull and shrouds.........1.025C
Water temp drop across rad with push-pull and no shrouds.....0.9C
Water temp drop across rad with pull and shroud..............1.275C
Water temp drop across rad with pull and no shrouds........0.95C
Water temp drop across rad with push and shroud...........0.975C
Water temp drop across rad with push and no shroud......0.875C
Air temp drop across rad with push-pull and shrouds.........4.5C
Air temp drop across rad with push-pull and no shrouds....2.875C
Air temp drop across rad with pull and shroud...............5.5C
Air temp drop across rad with pull and no shroud ........5.25C
Air temp drop across rad with push and shroud..........6C
Air temp drop across rad with push and no shroud.....7.5C
The best cooling came from the use of fans in a push-pull configuration with shrouds. I'm actually surprised with this much difference in the temp's.I was honestly only expecting a C or at the most 2C difference.
My shroud is only 3/4" on the pull side and 1/2" on the push side.Optimum is supposed to be around 1.5". I'm going to have to get some 1.5" aluminum channel and make some. And I hope it will make as much of a difference as the 3/4" shroud has.
After this simple test I would say a shroud is mandatory not optional for optimum cooling.
Part 3 with 4 lower cfm 120x25mm fans in pull with shroud to follow soon.
I tried 4-47 cfm Yate Loons on a 1.25" shroud in pull. I'm surprised
how well they did.As before I ran my CPU at stock which produces 89W.My320WTEC was running at 12V or 226W which gave me a total heat load of 315W.
As before I ran Prime 95 large FFT's for one hour,the highest and lowest
temp's were removed and the other 4 were averaged out.Idle temp was recordedafter 15 minutes of idle.These fans are the typical 120x25mm ultralow cfm fans.
Attachment 55291
Attachment 55339
Idle -----Minutes ------10 -----20 ----30 ----40 ----50 ----6o --Average
Ambient-25C -----------25 -----25 ----24.5 --23.5 --23 --22.5 --24C
CPU- -2C ---------------10 -----10 ----10 ------9 ----9 ---10 -----9.75C
Water in-32.5C --------33 -----32.9 --33.2 ---32.7 -31.9- 31.7 -32.625C
Water Out-31.7C ------31.3 ----31.8 --32 ----31.7 --30.3 -30.3 -31.325C
Air in-31.7C -----------26.5 -----26.5 ---26.5 --25.5-- 25--- 25 --25.875C
Air out-26.5C --------26.5 -----28 ----28.5 ---27 ---26.5 --26.5 -27.375C
CPU Temp average 24C
Room ambient temp average 24C
Water into rad average 32.625C
Water out of rad average 31.325C
Air into rad average 25.875C
Air out of rad average 27.375C
4 47cfm Yate Loons on a 1.25" shroud in pull average temp below ambient 14.25C
2 -108 cfm Sunon and 2 -115 cfm Panaflo with a 3/4" shroud in pull average below
room ambient 21.125C
2 -108 cfn Sunon and 2 -115 cfm Panaflo in pull with no shroud average below room
ambient 18.125C
These fans were running 3.875C hotter then 4 100+ cfm fans with no shroud.
And 6.875C hotter then 4 100+ cfm fans on a 3/4" shroud.
I have been suggesting 100+ cfm fans on these rad's after this test I would say they will do fine with something like the 120x38mm Panaflo 69 cfm fan.Perhaps some of the higher cfm 120x25mm fans would work as well.I have been under the impression that these rads only worked well with high pressure and higher cfm fans.This test kind of blows that out of the water.
I think I realize why these cool as well as they do to.The tubing in the rad has 2 rows of 0.05x0.75" internal tubing.That produces a lot of turbulence and a filming action.Older type of rads produced turbulence by trying to be unrestrictive and were flow dependent because of it.The way these are set up you should be able to get turbulent flow even at lower flow levels since its forced to be turbulent.Of course the higher your flow the more turbulence you will get with the higher pressure..
Reactions: 2
Very elaborate testing there ira-k !
Push pull appears to have a lot more impact than originally thought.
Big rep for all the hard work !
Thanks I lost my format with the # I'm still trying to make it readable...Take a look at the PDF till I can straighten this out..
Reactions: 3
I already downloaded it and saved it !
Too bad a person can't insert tables into this forum ... would make life oh so much easier when posting data tables eh ?
Originally Posted by Martinm210
Great test results, looking forward to seeing it all
Thanks Martin...This started out as a simple test and then I kind of let it snow-ball on me...Its fun though...I can't get my charts to paste with the text so far... Looks like I might have to type it all out...yuuuuuch...
...I'm glad I have the PDF or i would be pulling my hair out by now....
Ira, seeing as how your CPU temp seems to be quite low, this is with your TEC, right?
Did I read that correct and that you were only hitting 21C with the 320W TEC and running in passive mode?
Yeah...Thats sick isn't it...
..That truely amazed me..With the Pelt and cpu I'm not even starting to load this rad up...And thats with the shroud and fans still on once I get them off and it would cool a lot better..Thats why I decided to try it with some little 120x25mm low cfm fans in my third test....This thing might make a killer quiet computing rad for guys who like silence...Bet your glad you bought one now...
Yeah charts don't work well, but the pdf works great!
Well you've confirmed the pull is better than push, and push/pull is even better yet.
Looking forward to the low cfm fan and shroudless. Testing as long as you have and the number of times is awesome...thats the only way you can really tie down the numbers when they are only a few degrees apart.
Great example of how it should be done..
Oh...and I thought it was hot here being 25C...at least it's not 29!..lol
wow very nice temps and test....TEC huh....
hmmmm lol.....
BTW guys...
whats the "AUX" in speed fan?
mine is showing 119C!!!!!!!!
and what is the "system" reading considered as?
Very well done Ira. I've now added this and your cleaning PDF to there very own Ira-K FAQS folder under Custom WC.
niice, looking forward to seeing results with shroud, push and pull compared to no shroud.
Thanks Guys...I still haven't gotten the charts to do right...Its more of a pain then the testing was...
Well I have the second part W/O shrouds done except for the passive test...I really cant believe they make as much of an impact on cooling as they do..I was only expecting a C or two difference....
No PDF for part two I will combine 1-4 in one PDF when I'm finished with all 4 parts...
Awesome work, great job! I need to fab up a shroud now
Thanks...Yeah I need to make some 1.5" shrouds now and see if that is really is the optimum thickness for them...Thats a heck of a temp drop for a couple of bux...
I bent mine out of 2.3mm flat stock aluminum @ a height 0f 3", which allowed me to mount the 38x120mm fans on top for overkill or on the inside for optimal 1½" rise. The temp difference was 4-6ºC as I recall.
Originally Posted by Dryadsoul View Post
I bent mine out of 2mm flat stock aluminum @ a height 0f 3", which allowed me to mount the 38x120mm fans on top for overkill or on the inside for optimal 1½" rise. The temp difference was 4-6ºC as I recall.
Was that just on a pull or a push-pull? My pull shroud is 3/4" and push is 1/2" I'll just screw those 2 together and use it on the push side, then go ahead and get a stick of 1.5" channel to make my pull shroud..Then I'll try them thicker...
1 - 20 of 65 Posts
