i dont think you can do it on the partition that the OS is on. i wouldnt do it because i wouldnt risk loosing data. back up your data and try it, if it doesnt work at least you have your files.
good luck
good luck
Originally Posted by eflyguy ![]() If there is enough space to do it, Windows can resize the partition for you. ..a |
