1 - 9 of 9 Posts
so i'm desining a new partion table<br />
<br />
<br />
hda1 = root = 16779861 =jfs<br />
hda2 = home = 12586927 = ext3<br />
hda3 = swap = 6353707 = swap<br />
hda4 = boot = 3357585 = ReiserFS<br />
<br />
i have ext2, ext3, reiserfs, xfs, and jfs to choose from<br />
any suggestions?
9 Cans of Ravioli
Run Ubuntu. Choose to install to C:\\ or make a new partition. After that, everything is automated.<br />
<br />
<img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" />
dont use reiser as your boot partition. Use Ext3. Less hassle. Use Ext3 on both root and home too. Ext3 = stable = less hassle = better compatibility
Discussion Starter #4
if gentoo says that these are compatible, they sound better for a file system.
Discussion Starter #5
ok i'm going for it
<tr>
<div>
Originally Posted by <strong>General</strong>
</div>
<div style="font-style:italic">so i'm desining a new partion table<br />
<br />
<br />
<br />
any suggestions?</div>
</td>
</tr>
</table>
</div>I thought you could only use ext2 on the boot partition, LOL last time I installed Gentoo I formated it as reiser and got an error after I rebooted. LOL 5 hours a waste.<br />
root and home though Reiser(thats just what I always use) and you actually don't format the Swap as 'swap' you just select it as the linux-swap mount point.
If you are looking to have a common medium for both xp and linux to work from I would suggest adding a fat32 partition to the setup so that you can hold your media in a common location for easy access. Do you have the Gparted live disc? you should really get it. It is a life save for managing partitions on multiple systems. I use it all the time. But I must admit that with my recent work schedule I often get to one of my computers and have no idea what files are on it. My laptop is the only think that seems familiar to me now.
<div>Originally Posted by <strong>SpookedJunglist</strong></div>
<div style="font-style:italic;">If you are looking to have a common medium for both xp and linux to work from I would suggest adding a fat32 partition to the setup so that you can hold your media in a common location for easy access. Do you have the Gparted live disc? you should really get it. It is a life save for managing partitions on multiple systems. I use it all the time. But I must admit that with my recent work schedule I often get to one of my computers and have no idea what files are on it. My laptop is the only think that seems familiar to me now.</div>
</td>
</tr></table></div>
I disagree. I think you should just format the linux how you want it, and just give windows access to your home partition using the ext3 driver:<br><a href="http://fs-driver.org/" target="_blank">http://fs-driver.org/</a>
Reactions: SpookedJunglist
<tr>
<div>
Originally Posted by <strong>drummer4lifex</strong>
</div>
<div style="font-style:italic">I disagree. I think you should just format the linux how you want it, and just give windows access to your home partition using the ext3 driver:<br />
<a href="http://fs-driver.org/" target="_blank">http://fs-driver.org/</a></div>
</td>
</tr>
</table>
</div>Cool thanks for the link. I never saw this file yet. I will definatly add it to my system. Rep+
1 - 9 of 9 Posts
