1 - 5 of 5 Posts
I have $300 to spend on my next parts...case is done with.. what part(s) should I order next which are new and won't have any new parts replacing them?
Daves not here man
Hey, I would definately go wtih the pentium d 805, but switch things around a bit... The cpu is obvious and needs no explanation, the cpu fan, well nothing touches it in that price range. I went with that mobo because its extremely flexible, (ddr, ddr2, agp, pcie), and cheap, while still allowing an overclock of about 3.3ghz-3.4ghz, plus plenty of options.
CPU - Pentium D 805 $94.99
http://www.newegg.com/Product/Produc...82E16819116001
CPU Fan - Arctic Cooling Freezer 7 Pro $16.99
http://www.newegg.com/Product/Produc...2E16835186134R
MOBO - ASRock 775Dual-VSTA $56.99
http://www.newegg.com/Product/Produc...82E16813157092
After this, its completely up to you. You have approx. $130 left and could upgrade the gpu with an x850xt pe or a 7600gt. OR, you could get rid of that ram and go with a gb stick of ddr2. Sell your old stuff and probably get both.
Sapphire x850xt pe: $124.99:http://www.newegg.com/Product/Produc...82E16814102059
eVGA 7600gt, $129.99:http://www.newegg.com/Product/Produc...82E16814130062
1GB OCZ S.O.E.DDR2 667, $107.99:http://www.newegg.com/Product/Produc...82E16820227114
1 - 5 of 5 Posts
