Welcome to my build log.
This is my second Parvum build but first build log so any comments/feedback will be much appreciated.
The build will be a Republic of Gamers theme with vertical mounted GPU and mini ITX motherboard.
Cooling will consist of triple rad mounted at the front and a single in the top.
MAIN COMPONENTS
CASE: Custom, ROG themed Parvum vertical GPU mini ITX case
CPU: Intel i7 4970k
MB: Asus Maximus VII Impact mini-ITX ROG motherboard
RAM: Corsair Vengeance Pro 2133mhz
PSU: Corsair AX860
VGA: Asus GTX980
PCIE SSD: Plextor M6e 128GB M.2 PCI Express SSD
HDD: undecided
CABLES: Ensourced Custom Computer Accessories
Lighting: Darkside LED strips
Fan grills: Mayhems Spiral Fan Grills
WATERCOOLING COMPONENTS
CPU BLOCK: Bitspower AIZ97M7IITX Nickel Plated Full Cover Block Red
MEMORY BLOCK: Bitspower Universal RAM Module Water Cooling Set For 2 Banks 2-DIMMs - Red/Red
VGA BLOCK: Bitspower VG-NGTX980 Acrylic Top With Stainless Panel (Clear)
RES: Bitspower Single D5 Top Upgrade Kit 150 Black POM Cap
RADS: Magicool G2 Slim 360MM AND 120MM
PUMP: EK-D5 PWM
FITTINGS: Bitspower Compression Fitting For hardline Tubing
RIGID TUBING: Acrylic
COOLANT: Mayhems
