All flash memory will degrade over time, unfortunately nothing you can really do. However, most generation 2 SSD's are rated at 20 or more years for normal usage. You might use the drive for what 2 years max before upgrading? SSD's are going to have huge storage increases at a lower price in the next few years. I went with a 160gb SSD because overall everything runs soooo much faster when installed right on the SSD instead of having to access it from an HDD. It's up to you what you want to do but that 32gb will fill up awfully fast.
I can give you something to think about though. If you game alot and want to put the games you play most on the SSD, load times are much faster, and any application installed on the OS will run much faster but you won't be able to fit many on the 32gb drive. If I were you i'd spend some extra cash and get a bigger drive such as the 80gb X25-m
