1 - 20 of 61 Posts
Alright guys, I probably won't be doing a build for a while but I have a few questions about a theory I have with submerging a pc in liquid, then putting that inside of a freezer. I got this idea from this link http://quantumbioserver.com/ecm.html (it is the second project called ECM-2) and its not very discriptive at all. My first question is if he is using TEC or not. its kind of hard to tell because of how unclear his step by step guide is (if you guys find a more detailed guide to something similer please let me know). and if you guys figure out why he has the pump please let me know.
what I want to do if I ever get around to a computer build is submerge my computer in mineral oil inside a small fish tank, put it in the freezer, (I was looking at a $190 US freezer that cools up to .4 degrees F and that is equal to about -17 C and sense mineral oil freezes at -22 degrees F I shouldn't have a problem with freezing my oil). then wait until the mineral oil reaches lowest temp, turn pc on and OC OC OC!
I understand he may have been using TEC. if someone could explain to me how he specificly used the freezer and the oil to do it that would be nice.
a few more questions I have are even if he still is using mineral oil to submerge parts is it possible for condesation to get into the fish tank? if so how can I prevent it. any replys are appreciated
well if you where to do this you would have to somehow set the thermometer in the freezer to always work at a certain temperature, that is really why putting a pc in freezer/fridge does not work. fridge is always getting warmer so the cooler of the fridge is constantly working and it causes it to die rather quickly. so unless you want to pick up a new freezer every month-couple months(assuming it lasts a month) then i would say try it but it would be cheaper to just have a phase change unit in the long run.
Fettered Firewall
Oh boy..
Take cover.. INCOMING!
Originally Posted by Ictinike View Post
Oh boy..
i already explained why it does not work but I'm hiding under my desk just in case
On very old or low TDP computers then it is clearly possible to run a computer in a freezer, I'm talking ATOM kind of power computers - maybe 20-30 watts. Although freezers are capable of keeping many litres of food cool for long periods of time, it is actually shocking how little power they use, freezers are FAR TOO EFFICIENT at cooling food to be able to have the raw cooling power to cool your average computer.
Fettered Firewall
I know.. I read
Just these always gather a large crowd.. Last one, whew, went way to far and the guy went off the handle..
the oil gets very think as it cools down, it wont take long for the oil to heat up, and no a freezer cannot keep the oil cool
it will also kill the freezer
no, the difference is, the food isnt producing heat, its just hot that cools down and stays there
if you put a dog in the freezer, the dog will take forever to cool down, it will keep it warmer in the freezer keeping it running until temp drops
you put a dead dog in there, it will run, cool the meat, then shut off
freezers/fridges are built to hold non-heat producing objects at a temperature, not cooling a heatink object
Exactly. A refrigerator or a freezer is designed to cool down an item once. You put a steak in the fridge, it gets cold. This way the compressor only runs briefly every once in a while to maintain a general system temperature. But they are not designed to cool something that is constantly generating heat. This will cause the compressor to run too often, if not constantly, and it will quickly burn out.
I can't count the number of times a thread suggesting something like this pops up. And I'll warn you, every time one does, the OP gets stoned, beaten to death, and then stoned again for good measure. Its not that we're mean - its just a really bad idea to use a fridge/freezer.
alot of them lol, theres a sticky too lol
just look, theres atleast 15 people looking at the thread and/or typing up flaming posts
Discussion Starter · #13 ·
How about this then. Putting a very large radiator in the freezer, using a 1200gph pump (yes they do exist, for 10 dollars) cooling and cirulating the oil that goes through it then back to the fish tank. that can't create too much heat can it?
NOT COOL
its still the same thing, if you dont mind, if the same concept as i have quoted in my sig
though it might sound like less, your still dumping the same amount of heat in the cooler
also, 1200gph pump wouldnt help, it would burn up, you would need a pump for oil
Originally Posted by crashnburn_819
NOT COOL
Well said
it was just an example ><, i coulda said grampa
beerchiller/freezer/fridge
all the same thing, all same purpose, all for the most part made the same way
Beer chillers are not the same! Not the ones that are for draft beer
But sure, they do use the same expanding gas bla bla bla
It would all come down to how long the refrigeration pump lasted
alright, what if I have one radiator go on air first, cooling it down slightly, then have another one in the freezer cooling it down even more. and you can pump oil through a pump.
You wont let this go will ya, not til it's too late and the Wolves turn up
Discussion Starter · #19 ·
Hey if he can do it I want to learn how too. does anyone know what kind of method a supercomputer cools itself with? I remember him meantioning it was something like that. and did anyone even read the link? all the way through?
I say take a large ish container that will fit in the freezer and freeze a rad into it and see if u can get better temps....its cheap and easy and we all know freezers can make ice so. It wouldn't be constant unless maybe u left the block freeze solid then the ice itself will help assist the freezer and prolong the life. The only problem i see is that the ice may melt to rapidly.
1 - 20 of 61 Posts
