1 - 20 of 60 Posts
Skating Enthusiast
My friend wants to build a new PC. He bought a GTX 1080 like a couple months ago and just has it sitting in a box next to his existing computer -- an alienware prebuilt with a GTX 745 or something and an i7 4970X (4-core CPU). He's going to buy some sort of 27"~ 1440p 60Hz monitor so he'll be gaming at that res. He won't be overclocking anything. Air cooling.
Parts:
CPU: Intel Core i7 7700K
GPU: GTX 1080 (bought already)
SSD: Samsung 850 EVO 500GB SSD
RAM: 2x8GB (undecided)
MOBO: Undecided
PSU: Undecided (~800w is okay without OC?)
Case: Undecided (Full or Medium size.)
CPU CLR: Undecided (Air cooler.)
Monitor: Undecided (1440p, 60Hz~, probably IPS.)
Any suggestions / advice would be appreciated.
Update: Current Parts:
RAM: 2x8GB Corsair Vengeance LPX 2400
MOBO: MSI Z270 Gaming M3 Motherboard
PSU: Seasonic G-550 Gold 550W Power Supply
Case: NZXT H440 Mid Tower White
CPU CLR: Cooler Master Hyper 612 V2
Not new to Overclock.net
Regarding the PSU, a nice 550W PSU would still be more than enough.
Senior OCN Member
As said you dont need that huge amount of wattage
As for the other parts it depends on how much he can spend
Skating Enthusiast
Discussion Starter #4
Good to know, thanks!
I think middle of the spectrum in terms of pricing is probably quite good, more or less. Good value appreciated.
Senior OCN Member
Middle of spectrum is not all that helpful but i can make some suggestions and let him decide
For the air cooler how about a Noctua NH-U12S a Phanteks PH-TC12DX or a Cryorig H5?
For the case the Phanteks Enthoo Pro or Pro M which is the mid tower version
For the monitor the Asus PB278Q or the MG279Q, there is also the Asus PG279Q and the Acer Predator XB271HU but those are not cheap monitors by any means
Skating Enthusiast
Discussion Starter #6
Yeah that'd be great, thanks. Will check those out. Don't worry too much about budget. Just some suggestions will help us sort out what he wants exactly
Senior OCN Member
While they are the most expensive the last two monitors are also the best as they are 165 Hz and they have Nvidia G Sync
The MG279Q is 144 Hz and has AMD Freesync instead
The PB278Q has no AMD or Nvidia sync technology and is only 60 Hz
I used to have a PB278Q before i bought a PG279Q and while its not a bad monitor its not a gaming monitor so my advice is not to consider it if he can afford one of the other 3
Just threw it in there because itrs cheaper
Avid Memer
I wouldn't recommend your friend to give up cores and threads. The i7-7700K has better IPC than the i7-4960X, but fewer cores and threads. It makes much more sense to go with an i7-8700K. I personally think changing the motherboard and CPU isn't worth it since the goal is 1440p60 gaming. The video card upgrade alone should accomplish that.
i7 8700 + cheap cooler. Cryorig h7 or i like the little bit cheaper m9i.
3200mhz memory with 16-18-18-38 timings or better. Gskill owns. Memory prices are threw the roof!
Z370 mobo. Any will do. Asrock extreme 4 or k6/ asus prime-a. Gotta keep an eye out for sales.
Fractal design meshify c or phanteks enthroo pro m with arctic f14 value pack fans. comes to like $5.50 a fan!
Seasonic focus gold plus power supply. 550-850w will do fine!
Dell and acer makes 1440p gsync gaming monitors. TN panels. IPS is more $$$.
Samsung ssd...
This guy's on the right track. At 1440/60hz that GPU would probably push it on a potato. Put the GPU in the current system and buy an appropriate monitor, like a 1440/144hz and then see where any deficiency is and go from there. Things like an SSD, better air cooler, new power supply etc, could (probably) all just be retrofitted into the existing case, or retrofit the core components into a new case. Whatever works.
Skating Enthusiast
Discussion Starter #11
Thanks! I think he'll probably stay away from high Hz and 4k monitors.
I think he's thinking around $450 for the monitor. So just a good 1440p 60/75Hz 27-32" IPS monitor would be good.
Perhaps I named the wrong one, but it's a 4-core with 8 threads. So the i7 7700K should be plenty.
Samsung ssd...
Thanks! Do the Z370's work with the i7 7700K, etc., I assume it does?
Will check those out!
The current system is a very slim form factor and putting parts into it would be an absolute pain. We discussed keeping the current CPU and just refreshing some other components but he wants a new system. Gaming wise I don't think there's a big difference between the i7 4970X and the i7 7700K so it'd save like $600-700 AUD if we kept the mobo and CPU but then we need to buy older RAM as well.
Senior OCN Member
A Z370 board will as far as i am aware not work with 6 and 7 series of CPU´s which means you need a motherboard with a 200 series chipset
Avid Memer
If you're not adding cores or threads, I don't think an IPC upgrade is worth it. Your processor is either Ivy Bridge-E or Haswell. Skylake and Kaby Lake aren't enough of an architectural improvement for me to think the upgrade is worth the money spent. Coffee Lake would at least give you more cores.
Skating Enthusiast
Discussion Starter #14
OK good to know. Thanks!
According to Intel the fastest RAM is 1600MHz for the i7 4790K. Isn't it worth moving to i7 7700K and getting ~3200MHz?
That's the fastest native support, but enthusiast motherboards extend that support very far.
Skating Enthusiast
Discussion Starter #16
I see I see. What sort of mobo should I be looking for? For the 4790K? Is that still 1151?
Avid Memer
No, LGA1151 is Skylake, Kaby Lake, and Coffee Lake. Haswell and Broadwell use LGA1150.
A nice Z97 motherboard would be a good, but all you really have to do is look at the motherboard's specs to see what the memory support is.
Skating Enthusiast
Discussion Starter #20
Originally Posted by spinFX View Post
Yeah throwing in another vote for either going to 8700K or stick with the current gear and spend all the money on a new GPU and some flashy peripherals (new case, nice monitor etc).
I don't think he wants or needs a 6-core so thinking perhaps keeping the existing CPU and mobo is a good idea.
He's already picked himself up a 1080.
Ahhh I see.
Perhaps keeping his current i7 and mobo is a good choice. That'll mean new PSU and case and probably a decent cooler. He doesn't need too much else.
1 - 20 of 60 Posts
