PC to PC transfer speed
343 Views 9 Replies 4 Participants Last post by  APOLLOSTEES
My PC to PC transfer speed is horrible. Vista is reporting it at between 4-15mbps. I got this transfer speed directly from the copy file window under the "more information" tab. Could this be wrong?
Here is my setup:
2 PCs running Vista (these have NO av software)
1 D-LINK DIR-615 router with 10/100 ports.
Cat 5e cables runs, and ethernet cables.
I was thinking of upgrading to a gigabyte switch but I'm not getting anything close to 100mbps transfer rates.
Any clue as to what my problem is?
1 - 10 of 10 Posts
I could be mistaken, but on my system here, Server 2008 (mostly Vista) lists the speed in MB/s not Mb/s. So 100Mb/s would roughly correspond to 12.5MB/s.
So your saying the report is in BYTES not BITS?
Here is my setup:
Those speeds seem about right to me, you'd need to run gigabit for some better speeds.
thats true. both nic and router needs to be giga.
But 10/100 ethernet has a top speed of 100mbps. And I know that is a max speed under the best conditions, but still 100 to 4 thats a huge difference.
1024mbps= 1MBps
are you downloading or anything else while transfering? what about open programs?
Sorry, my brains moving slow today.
So you guys are saying that 4-15MB would equal roughly 30-120Mbps. OK, OK I think I'm understanding.
Originally Posted by noobdown View Post
1024mbps= 1MBps
Right idea, but not quite.
1 Byte = 8 bits
So
100 Mb/s = 12.5 MB/s
1 - 10 of 10 Posts
