Hey all my pc has been behaving odly the last couple of months.
At times it will refuse to switch on even if I remove and replace cmos batery, remove power and reset cmos etc. Even tried different power switches and the on board power switch. It will also randomy (not so often) switch itself on!
When it is working it works flawlessly, I've ran games, benchmarks, watched films, surfed the net, stressed and tested the oc etc and no problems.
However in addition to this, recently it's now started turning itself off as If the power was cut or the power button was held in... Help!
The pc is 4-5 years old now and I've had absolutely no problems with it whatsoever since I migrated it to a caselabs case, what could have happened?
Thankyou for your time and any help is greatly appreciated.
Just a little more info:
It's a 2600k @ 5 ghz
8 gigs of corsair ram @ 1866
And a 1200w enermax psu
2 gtx 580 sli (old )
Running windows 10
The issues I'm having happen no matter what bios settings (and vertion) I use (defaults etc) and running single gpu, one stick of ram etc etc. I've also tried a different psu and still the same issue :/
I'm starting to wonder if it's a short circuit, but where?!? I really don't want to have to dismantle my water loop :/
Cheers peeps!
Running windows 10
Cheers peeps!
