OK, so I've pretty much exhausted most of my ideas on this, and it has confused the hell out of me
My mate went against my advice and bought a PC from Tesco
Lo' and behold, it's warranty has just expired then it breaks
He said he was surfing the net and the screen froze, the computer then switched off. He tried turning it back on and everything would power up for 5 seconds then shut off again, no signal to the monitor or anything.
He then bought a new motherboard......when I told him he should check everything else first. As I predicted, the new motherboard didn't solve the issue. He still had the same problem.
I brought his PC to mine, put his CPU and RAM into my PC and it booted just fine.....obviously not the CPU and RAM. To be extra sure, I put my CPU and RAM into his system, and it still wouldn't boot. We then tried my PSU in his system...and it still wouldn't boot.
So now I have exhausted the CPU, RAM, MOBO, and PSU
I swapped out his HDD, still no dice. The mobo has onboard graphics so it clearly wasn't a GPU issue.
I then thought he may have set up the PC wrong when he bought the new mobo, so I stripped it down and put it back together. Still no dice!
I did notice that the back plate for his HSF had no rubber pad between the back plate and the mobo, and this could be shorting his pc.So I put a couple of layers of toilet roll between the back plate and the mobo to prevent contact, and still no dice
He did say that the backplate didn't have a rubber pad on his last board either
So in a nutshell, the only thing we haven't changed is the damn case!
The only two problems I can think of are:
The toilet paper wasn't enough to stop the back plate touching the mobo?
The new board was DOA?
System Specs:
Q6600 G0
Asus P5Kpl (onboard graphics)
300w Generic PSU
HDD
3GB RAM (1x 1GB, 1 x2GB)
I would really appreciate some input on this, I'm totally stumped.
