1 - 7 of 7 Posts
Here is the setup I am going for.
PC1 & PC2 connected via ethernet cable to old Linksys RT31P2.
RT31P2 connected via ethernet to PC3 which has a wireless adapter, which is wireless connected to a Linksys WRT54G.
All PCs are running Windows 7.
I can get PC1 & PC2 to connect to the network doing this, but neither connect to the Internet.
I have the wireless adapter on PC3 shared.
Suggestions?
Can you presice which router is internet connected ?
I would also ask.. why in your network do you need two routers ?
edit: after reading again, do you mean that you Wan port on the RT31P2 is connected directly to your PC3 ? and the internet is coming on the PC3 from the WRT54G wireless, and trying to get internet passes throught your pc3 to the RT31P2 router, then on your pc1 and 2 ? Precise more on your internet source plz ! I
edit 2 : Are you having any problem ? i mean, you say suggestions.. suggestions on what ?
I have to do it this way due to the location of the PCs and the availability of only 1 wireless network card.
I currently have it setup as:
Cable Modem > Wireless Router > Wireless PC > Ethernet cable from wireless PC to Internet port on Wired Router > Wired Router > Ethernet cable from Wired Router to PC2 > Ethernet cable from Wired Router to PC 3
The problem I am having is that PC2 & PC3 cannot access the internet through the wireless PC1.
OK update: I have since swapped out the old router I was using for a Linksys 10/100 Switch. It hasn't made a difference though.
On PC1 (the one with the wireless card), I can ping the wireless router, and PC2 & PC3 (the ones connected to the switch with the ethernet cable). I just can't get PC2 or PC3 to be able to ping the wireless router. Doesn't seem to make much sense. I can ping going in one direction, but not in the other. For some reason the packet is getting stopped at PC1. PC2 & PC3 can ping PC1, but cannot ping the wireless router "through" PC1.
1 - 7 of 7 Posts
