1 - 7 of 7 Posts
Hey I got a question... im running a crappy eMachines (T2085) and i figured i needed some more RAM, so i bought a 512MB DDR PC3200 one and when i serached on the internet, it said i should be using PC2100... but will it work anyway? and what will happen if i put it in?
it will work fine, all it will do is change its clockspeeds and timings to match that of the ram your currently using.
yeah, you're good to go. the new RAM will just be underclocked, but work fine
Originally Posted by ramapple
how come i've heard people say it might overheat or might screw the mobo up?
Because they have no idea what they're talking about
Yeah, you will be fine.
1 - 7 of 7 Posts
