Motherboard Model: M848A Rev 2.1 (Latest Bios from Pc Chips)
I have recently upgraded my cpu from a Athlon XP 2000+ T-Bred to an Athlon XP 3000+ ( Barton). I reset my bios with the jumper on the board and then put the new cpu in and attached the new cpu cooler. When i turned the pc on it boots and then gives a cmos error and tells me to check the settings like default.
So i checked all the settings and the Bios looks like it has correctly recognised the ram at 200 and the cpu at 166. So I reboot the pc and noting displays.
Then i had to reset the bios to get a picture back (using the jumper) I have got the latest bios from the pc chips site and applied it and the same thing happens. The motherboard will work if i manualy put it to the old 2000+ settings but it seams that anything above 2200+ does not work
My Vcore is running at 1.6V at the max settings I can get the cpu to boot at
