PCI-e slot issue on evga x58
352 1
Hi on the evga x58 mobo, If i install the gfx card in the primary slot ie the first one, then the pci-e x1 slot for my soundcard is blocked...Can I use the second slot? And will it work at full x16 bandwidth if i do? (it is supposed to have 3 pci-e x16 slots)....nothing about this is mentioned in the manual...
1 - 2 of 2 Posts
Yes, you can put it in the others.
1 - 2 of 2 Posts
