hello,
i want to add a pci e x1 usb 3.0 card to my system and connect the 20 pin usb 3.0 header from the front panel of the chassis to it. (my pci e slots on the MB are gen 2).
i see there is a lot of differnt types of cards out there. my question is do it need aditional power? or what it gets from the pci e slot is more then what it need?
from what i see some cards with sata power other with molex or even 6 pin power adapter and there is some with no aditional power (all the power they get is what the pci e X1 gave).
1) so do the cards with no aditional power will work?
2) if i buy one with aditional power and dont plug the aditional power it will work?
all i am trying to do is to avoide more cabels in my pc.
thx in advanced.
thx in advanced.
