1 - 7 of 7 Posts
Hey all, i need a little guidance. My new motherboard only has PCI-E. For some reason ive got the idea that it needs its own power from the PSU, with its own connector. Is this true. If so, could you help me choose a compatible PSU
A pci-e motherboard is just like all others. The PCI-e video you get or have may need a power. My 6800gt oc needs more power so I have a cable that hooks right to the video card
thanks for clearing that up
Rep+
I will also say that you can never go wrong upgrading the a better PSU. Thank of the PSU as the heart of a PC. The better the PSU is the better it will run in terms of more stable 12 volt rails
yep, as already stated some pcie cards require their own additional power since the mobo can't supply enough power to it.
the only instance that I know of where the mobo actually requires extra power is my board. the Asus A8N-SLI series. the board has a molex plug right above the first pcie slot... called ez-plug. it supplies a little extra juice when you're running SLI.
one thing I would note... most newer mobos that have pcie also require a 24pin atx psu. so it would be best to upgrade your psu to an atx2 complient psu that also has at least one pcie plug.
Thats true, mine needs a 24pin atx, 4pin p4 connector and an extra molex for the PCI-E
1 - 7 of 7 Posts
