1 - 14 of 14 Posts
would overclocking the pci e bus from 100mhz would cause any problems
Yes, it may cause silent data corruption.
so fried or 115 which one
Risks:
Data corruption.
Damaged components.
Benefits:
None.
Risk/Benefit analysis is easy on this one.
it controls everything on the pci-e bus which is usually hdd controllers and ethernet i know i have had hdd corruption at 110 and it gained no points in any benchmark i did from 3dmark to lightmark to furmark
Originally Posted by DuckieHo
Risks:
Data corruption.
Damaged components.
Benefits:
None.
data corruption ussally happens at 120. some older chip set it can help an overclock. and a higher pci e bux speed was proven to give 9600gts a boost in performance
Iconoclast
I've seen data corruption occur at PCI-E speeds as low as 105MHz, on an ICH9R with RAID in operation.
i was talking about non raid system
I have an Asus board that will not run any OC stable unless you set the PCI-e to 110mhz. I hate that board.
1 - 14 of 14 Posts
