PCI folding cards?
831 Views 22 Replies 12 Participants Last post by  sdla4ever
Are there any good PCI cards? I'm adding 2 8800 gt cards to my sig rig and I'll still have PCI slots. So mqybe I fill them lol
1 - 20 of 23 Posts
Not for the price... you need 8 series or better PCI cards. There's only a handful and not really worth it being so low performance.
Well I guess it's back to saving for twin GTX cards. Or another rig hmm
You can use your x1 PCIe slot for another single slot card.
You just need an $8 adapter (check my sig for info)
Originally Posted by tenchimuyo93
8xxx pci cards
9xxx pci cards
HD2xxx pci cards
not the best performing cards in terms of ppd but they get the job done.
$60-80 for 16SP? $90 for 32SP?
He could spend $60 for a single-slot 9600GSO with 96SP plus a $8 PCIe adapter instead. Same cost but massively better performance/efficency.
8xxx pci cards
9xxx pci cards
HD2xxx pci cards
Don't waste your money, these are all garbage.
OR try a PCI-E8x or 16X splitter! I'd like to see someone do that and daisy chain max gso's!
They have those?
I was looking around and trying to figure it if was possible.
I second that I want to see it go. Hmmmm my extra slot with a splitter x8/ 2 = x4 with 2 cards folding = more points regardless hehehehehe.
Chuck D
They have those?
Yeah man! go for it, I have too many things on my plate!
yea you may be right but the question was for PCI cards, i responded with the one that Could fold...... this is why im starting to hate coming here.
Then Leave, it would be ignorant to just suggest a PCI card that might get 1500PPD and cost more than a solution that works better, gets 3 times the PPD and is cheaper
Yes, but by thinking outside the box.... you can do more for less.
His question was really about PCI cards... it was how to increase Folding. Checking his mobo spec and components, we see there's a free x1 PCIe slot and we have a solution to utilize that.
We are trying to encourage...not discourage folding. Even I fold with an old PD-940 that might give me 500ppd but the points add up. If there are any 8 series Nvidia cards for pci then lets find them. Lets keep the spirit up for folding. I myself could be the last one, bottom of the list folding but I refuse to give up. With respect, lets tone it back and see what we can do.
These are 8 series. Need to check to see if any would work. Not sure due to no list for shader.
http://www.newegg.com/Product/Produc...e%208%20series
These are the 9 series listed.
http://www.newegg.com/Product/Produc...e%209%20series
Chuck D
No one was discouraging folding, DuckieHo was just saying that rather than folding on a pci card and getting very little PPD for the price he could use one of the PCIE 1x slots that's open and use a riser and fold with a PCIE card that will cost about the same or a little more and get 3 times the PPD.
lol try this x1550 it can play almost all DX9 Games should get *some* folding done
That riser will allow him to use a PCI16x not just a 1x card.
ok see ya. im done here.
This site is dedicated for getting more from less... that is what overclock is... instead of buying the $1000 CPU you buy the $200 one and make it run just as fast as if not faster then the $1000 one... you guys both made valid suggestions using different techniques, so let the OP decide what hes going to do... It doesn't mean you have to up and leave...
lololol
Last PCI card I had was a Viper v550 and it was 16MB.
It won't fold, but it'll be interesting if someone with a 233MX system will dust it out and churn some WUs. Think I had 64MB on that rig (beats the 486DX, which had 24MB).
1 - 20 of 23 Posts
