1 - 4 of 4 Posts
No it doesn't garner any kind of performance increase. The only reason you should have to turn it up would be if your computer will not display video on POST. Other than that you should keep it locked to 100MHz.
Hi Kenny, welcome to Overclock.net! I am going to go ahead and move this to the AMD General section, as that is where it belongs
. Just be sure to look around the forums and try to find the correct section to post in. If you are unsure about which section your question should go, send either myself or another Director a private message, and we would be glad to help.
1 - 4 of 4 Posts
