1 - 20 of 23 Posts
Originally Posted by Mr.Pie View Post
lol yeah i got a sapphire 5570 right now
but the PCIE riser can make the card like lie down on its side.......do you think?
But where would put the card, I can see no where for it to go without extensive modding
just like on the side right above the slots..........
and the exaughst along the IO
A single slot card would probably fit there however both the 5850 and the 5770 are dual slot cards(although I think someone made a single slot 5770).
Discussion Starter · #8 ·
I have the stock PSU inside right now,
i recently removed my aftermarket 500w PSU after trying it out
I could remove the PSU with wire coming in form the hole, then put the card next to it
I'll psot pics if I can later
wats the dimensions of the 5770 and the 5850?
Senior Member
Wasn't Duckie using them?
lol i dunno, i got the linky off somewhere here on OCN
anybody can give me the dimensions for the 5770 and 5850? reference designs only please (the V1 cooler) so i can vent the air out of the case if i upgarde
If I was you I'd just buy a cheap new case for about the same price as the riser card. Save any hassle and you'd never have to look at that Dell logo again!
Discussion Starter · #12 ·
lol this is classed as an "unautorized upgarde" so I can't do anything that changes the appearnce
i could change the I/O panel and stuff but liek the main stuff has to look the same
1St be more grateful your parents actually buy you stuff, my pc *new rig not in sig* i have had to sell and and save for months to buy,
2nd, save and get a new pc?
3rd, Get a job?
4th best idea would be to get a new case and i agree with everyone else...unless you want to get a dremel and cut a huge gape in your case and add some extendedness to it, you could probably buy a new mobo and case and after market hs and a new GPU and you would be sorted.. ^^ And if your rents dont trust you enough to build a pc then it might be because they paid for it and its there choice? ?
Discussion Starter · #14 ·
3rd, Get a job?
lol its actually a shared PC
I paid for my current 5570 GPU and the PSU and windows 7
2. No new builds they said
3. too young to get one
25 dollars and shipping for a connector adapter for PCIex16 plus several hours of pissing around or 60 on a budget mid tower.
Just go for a new tower and save the head ache plus have usuable tower for more upgrades in the future.
Discussion Starter · #16 ·
read thread,
this is an unathorized upgarde
You could just turn it vertically and put it where they would normally go, exhausting out the PCI-E slots. It's going to need somewhere to get air from, though.
Discussion Starter · #20 ·
Never to young i had a job when i was 13, second.. everyone here is saying the same thing what you want to do is possible YES but you have to cut your case up, so go for it! Or you could buy a new case.... end.. of....
lol no can do here in Hong Kong
no jobs for ppl under 15-16 i think
I'm only 14
well i do the occasianal odd chores for my parents so I do get some $$
1 - 20 of 23 Posts
