1 - 11 of 11 Posts
Old dog, old tricks
I just switched to PCLOS from Win10, and Steam wouldn't run.
It installs fine, from what I can tell, then when I try to start it, it says this:
You are missing the following 32-bit libraries
and Steam may not run:
libGL.so.1
I'm a total noob with Linux, so I don't know what to do, and I can't find a suitable solution in Google.
Old dog, old tricks
Discussion Starter #2
When I type "steam" in the terminal, I get this:
Couldn't find dpkg, please update steamdeps for your distribution.
Running Steam on pclinuxos 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1461972496)
libGL error: dlopen /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: dlopen /usr/lib/dri/swrast_dri.so failed (/usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory)
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Pls help.
Old dog, old tricks
So I installed dpkg and sudo, because it asked for it, and now I'm here:
This appears when I click on Steam on the desktop. What should I do now?
BOINC Cruncher
The libGL.so.1 library that Steam told you that you are missing is one of the packages it's trying to install in your screenshot. Go ahead and install them.
Old dog, old tricks
Discussion Starter #5
How? PCLOS comes with Synaptic Package Manager, searching it for libGL.so.1 gives 0 results. Pressing Enter on that last screen just closes it. What am I supposed to do?
BOINC Cruncher
sudo apt-get install libgl1-mesa-dri:i386 libgl1-mesa-glx:i386 libc6:i386
Old dog, old tricks
Discussion Starter #8
Old dog, old tricks
Discussion Starter #9
Nevermind, I just solved all my problems with PCLinuxOS by installing Ubuntu instead.
Everything works out of the box now.
Thanks for trying though
Odds are your apt-get was just not looking in right repositories.
Not to say cross pollinating repos are always advised, but it tends to be safe when you use Debian derivative and add Debian/Ubuntu repos to your list...
I have run Steam on Debian, it was ok. In anycase, I hope it doesn't run you off linux, but generally speaking, almost no matter what distro you
I am no cheerleeder for PCLOS, so just my 2Cents.
As always, I'd suggest trying Debian stable first and than kinda looking around for what you like more and getting that package in some distro, but if Ubuntu worked for you, all is well? ^^
1 - 11 of 11 Posts
