1 - 6 of 6 Posts
hey all,<br />
<br />
So today I got a full version of PCMark 05, but when I try to run some benchies (I just select all of them) and hit start, it appears to do 1 single test, and then it says 'Test Aborted' even though I didn't touch anything..<br />
<br />
Now, is this hardware related, or has this something to do with the program?<br />
<br />
I have internet explorer 7, windows media player 10 and windows media codec thingy 9, so I meet the requirements.
You have all your runtime updates for Dx9?
I have DX9 august, so I guess so..
You may find that it needs IE6 and not v7... check the requirements <a href="http://www.overclock.net/913008-post1.html" target="_blank">here</a>
Discussion Starter #5
Ya ok thats true.. but it says 'minimum requirements' so you'd expect that a higher version would suffice, right?<br />
<br />
And btw, I also get some weird error with 3DMark 05, wich I also have.<br />
<br />
IDirect3DDevice9:<img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />resentFailed: Device lost (D3DERR_DEVICELOST)<br />
<br />
I dont get this at all. I have Catalyst 6.9, the latest version of DX9.0C.. so *** is going on here??
Try running the tests at all stock settings, if these still fail then look at the OS and installed apps.
1 - 6 of 6 Posts
