Can't wait till the 15th to see how they stack up. Hopefully AMD gives Intel some competition in the mainstream market this generation.
AMD Trinity SourceThe upcoming Trinity processors bring quite a few enhancements to the table, foremost of which is a revamped CPU part that ditches the old Phenom II processor cores in favor of updated Piledriver architecture CPU modules. The move to the Piledriver x86 cores promises an increase in IPC, leakage reduction, CAC reduction, and increased clockspeeds according to the leaked slides, but the most important change is the increased performance per clock numbers. The Trinity APUs are set to replace the A8-or performance series of-Llano APUs with quad core Trinity processors that utilize two Piledriver modules that each share 2MB cache for 4MB of total L2 cache. In that respect, Trinity will be similar to Llano in that it does not employ any L3 cache that is shared between the CPU and GPU cores. Interestingly, that may mean that using higher clocked RAM can improve performance on Trinity just as it did with Llano. If true, that would make Trinity's improved DDR3 support-up to DDR3 2133MHz- all the better. On the GPU side of things, Trinity moves to a "Northern Islands" VLIW4 architecture with up to 384 stream processing units. Although the GPU area is physically smaller, it is said to be more efficient than the GPU cores in Llano APUs. The new GPU core is DirectX 11 and OpenCL 1.1 compliant. Also, it includes an updated hardware tessellator engine and hardware encoding unit (AMD Accelerated Video Converter).
