my thinking is to a take a 60 watt-100 peltier device right after the radiator sandwich in between a water block and a conventional cooler for the same CPU does not have to be the same CPU as whats in the system the idea is one side gets cold to chill the water the other side gets warm and is vented out of the case my thinking is to use a dell hood or something similar to directly vent this device and also insulating the water block would not hurt but not expecting to lose allot from that point my only worry is condensation so thinking I should insulate the tubing after the peltier device up to the CPU since not expecting the CPU block to stay bellow room temp after all of this what would be the safe temp reletive to room temp on a hot summer humid day my thinking is 10 degrees bellow room temp
and does anybody make pre insulated tubing my guess is want to avoid fiberglass and foam type insulation foam might be usable if covered with more tubing but do not want to stress the fittings a hard tubing might help with this rather it be strait runs only or tubing that resists bending enough to prevent extra pressure from the foam
